Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
NEED HELP
Old Aug 28, 2015 | 08:24 AM
Hondaboy089's Avatar
Default NEED HELP
Just put in a cold air intake on my 2009 v6 accord coupe. I installed it and it ran all day with no issues. The next morning the check engine light came on. I reset the ecu and then the light went off then when the car cooled off the light comes back on... Any ideas?
Old Aug 28, 2015 | 09:49 AM
MSchu's Avatar
My Name is Nobody
Default Re: NEED HELP
re-install oem air box.
Old Aug 28, 2015 | 02:45 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1. Get the trouble code and post it. Depending on where you live, most Autozones, etc. will read the code for free.
2. It probably is due to an issue with the MAF sensor (e.g., dirty, etc.) and/or a air leak in the intake system. You may have a trouble code like P0171.
Old Sep 19, 2015 | 05:43 AM
Old Sep 19, 2015 | 05:45 AM
Alright i will. I cleaned the maf sensor and all.. Even when the light come on it still drives like normal. Idk if its a lean code. But i ll get the code pulled
Old Sep 21, 2015 | 05:51 PM
III's Avatar
III
is there a "home" way to get the codes? i remember in my 97 CL you could stick a paper clip into this plug, and flip the key and count the flashes or something like that... i just encountered this same problem on a friends 2010 accord V6... was fine yesterday, but today he says CEL is on...
also, how did you reset the ecu? thanks
Old Sep 24, 2015 | 03:46 PM
poorman212's Avatar
Not sure on the '10 but yes there are "home" methods to get codes....however with modern cars the actual codes are needed as they will give a better idea of the circuit/system that needs to be tested.
Old Sep 26, 2015 | 12:56 AM
III's Avatar
III
unfortunately i figured that, i remember with the CL it was a matter of counting flashes and then looking online to see what codes meant what...
in my case, the way the intake pipe is situated, the MAF is actually sitting upside down... this may be a stupid question, but would this be a leading cause as to why the CEL is lit up ?
Old Sep 26, 2015 | 04:33 AM
poorman212's Avatar
If you don't want to/can't get the actual code........put the OE set up back on the car and go for a few drive cycles - a week or so - and see if the CEL goes out? We really can't help much more than that with the information given.
Old Sep 27, 2015 | 09:56 AM
just got it pulled and its a p0172 p0175 to rich... so now what?
Old Oct 12, 2015 | 01:58 PM
III's Avatar
III
we got the same two codes as well (which i coulda figured was coming)... but whats the solution on how to clear it... ?
Old Oct 12, 2015 | 05:33 PM
I guess get a tune of go back to oem airbox... I want to know what program to use to tune the 2008-2009 accord coupe v6. I dont see anything from hondata
Max Spider X
Mar 30, 2014 05:09 PM
godruler
Oct 12, 2009 06:48 PM
xluben
Feb 25, 2007 01:54 PM
hatchblack
Honda S2000
May 3, 2006 10:55 AM
anothersickhatch
Apr 15, 2004 12:26 AM
