Darton b18c sleeved shortblock/head tilton twin disc clutch
Victor x b16 manifold w/oem t-body & all sensors $225 sold
Aem fuel rail/pressure regulator $125 SOLD
Crane oo12 b-series v-tec cams /factory cam gears $300
B16 head w/valve cover/v-tec solenoid super tech flat valves/springs/retainers/locks fresh valve job $650
Oem obd2 gsr distributor $150
Arp head studs v-tec torqued once $75 SOLD
Shortblock
Price...$2500 obo
Darton sleeved b18c1 84.5mm
Arias pistons 9.5.1
Eagle ls rods Arp 2000 bolts
Ls crank
Acl race bearings mains/rods
Oem timing belt
Oem oil/water pump
Oem gsr oil pan w/10an drain bung
Eg aluminum radiator w/fan $100 obo
4 to 1 Dc sports header $100
Tilton b-series twin disc clutch that was purchased from ipg awhile back came out of 1 of there cars it was rebuilt and has same amount of run time as motor since rebuild $900 obo
Neptune rtp demon w/bbg/clear cover In a p28 ecu $300 pending until Friday
Ziggybuilt 4bar map sensor for b&d series $50
The motor or clutch has no driving time just run time in front of the shop & that was on stock injectors & DC sport header assembled by sharps machine shop
Ek mvr b-series solid mounts $100 shipped
T1 900 hp intercooler w/charge pipe/clamps/couplings 3inch in 3inch out single back door $700
BMC b-series t4 twin scroll top mount w/dumptubes 500
2 tial 44mm wgs $275 apeice
4inch v-band down pipe $150
Shortblock
Price...$2500 obo
Arias pistons 9.5.1
Ls crank
Oem timing belt
Oem oil/water pump
Highboostedsol
May 16, 2016 09:32 PM
Highboostedsol
Aug 28, 2015 07:08 AM
