Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
'05 Pilot J35 intake gaskets, reusable?
Old Aug 27, 2015 | 06:18 PM
MAD_MIKE's Avatar
MM Gruppe B
Default '05 Pilot J35 intake gaskets, reusable?
Neighbor's '05 Pilot(230K miles) is spitting out misfire codes, checked the plugs #2/#4 were less than finger tight. Replaced plugs, rough running and cold start issues went away, but misfire codes came back. I suspect EGR is clogged and/or the valves are in need of adjustment.
Are upper egr plenum cover, upper intake, and valve cover gaskets reusable?
I *think* this year Pilot uses the reusable metal shim gaskets for the plenum and intake but would like confirmation.
Thanks in advance!
Old Aug 30, 2015 | 01:49 AM
poorman212's Avatar
Default Re: '05 Pilot J35 intake gaskets, reusable?
I didn't chance it, had to adjust the valves on the '07 last year. Not a fun job getting to the rear valves but I made it through.
Anyway, I went back with new gaskets just to be sure I didn't have to go back in.
Old Aug 30, 2015 | 11:20 PM
MAD_MIKE's Avatar
MM Gruppe B
Pulled the intake off and the gaskets were MLS gaskets with a permanent ridge in them for sealing. Similar to the EGR manifold gasket on my Accord. I cleaned them up and reused them. No issues.
FWIW, last 'major' service done was at 100Kmiles. EGR ports were all clean, Intake valves were fine, all the exhaust valves had NO clearance. Engine sounded so much better after adjustment.
Old Aug 31, 2015 | 02:47 PM
poorman212's Avatar
Glad it worked out for the neighbor
JdsAccord
Dec 31, 2016 11:11 AM
goldminer
Aug 12, 2015 02:50 PM
accordmatt
Feb 16, 2011 06:32 PM
sick_dc2
Nov 22, 2008 01:33 AM
