Up for sale is my 1989 Honda Civic Si w/ 169,000 miles. Have owned it since 2011, don't really wanna sell but i need the money to payoff somethings.
I'll start of with the bad things with the vehicle:
- Was involved in a collision a couple of years back and was hit in the passsenger door/fender area. The passener door was replaced!
- Sometime last year, someone backed into my civic and hit the front right corner light area. As you can see in the pictures that area needs to get straigthened out a bit so the hood can sit flush.
- The front lower crossmember is bent after hitting a section of raised asphalt
- The transmission sometimes gets a little notchy but nothing serious i'm not sure if it has to do with bad bushings on the shift linkage, the drivers side axle seal need to be replaced. The drain plug was stripped by the previous owner.
- Brakes need to be replaced. For an extra $250, I'll throw in EX knuckles with fresh rotors and brake pads, plus 2 BNIB Moog Lower Ball Joints.
- Tags are up after this month
Just recently replaced the timing belt, also installed A/C not to long ago. Tune-up was done last year as well and the RTA bushings were also replaced last year with moog units.
Asking for $2250 with Crimson Sparco Racing NS2 4x100/4x114 15x6.5 and the Ground Control OTS kit.
Asking $2000 with the EX Knuckles
Asking $1750 without wheels and coilover sleeves
