Starter Motor Location
Old Aug 27, 2015 | 05:38 AM
HAMZAEP3's Avatar
Post Starter Motor Location
Hi everyone
Does anybody know where the Starter Motor is located on Honda Civic Type R EP3
And a how to guide to replace it
Old Aug 27, 2015 | 07:43 AM
Jujutsuka's Avatar
Default Re: Starter Motor Location
Originally Posted by HAMZAEP3
Hi everyone
It's under the Intake Manifold.
For easiest access you'll need to take off Intake-Throttle Body-Intake Manifold. For clearance loosen up the Radiator Frame and the screw at the bottom of the T-frame. That way you can push it back to clear your intake manifold. Then you'll have clear shot and leverage to take off the two bolts of the starter and the screw that holds the positive terminal underneath the rubber boot on the starter.
I think ClubRSX has a DIY for an RSX, that will help you.
Old Aug 28, 2015 | 12:32 AM
HAMZAEP3's Avatar
Thanks for the reply mate
Iv been reading on other forums came across also you can change it from the bottom of the car
Old Aug 28, 2015 | 04:52 AM
Jujutsuka's Avatar
I guess it's possible if you have the tools and you can do it without looking at it.
But if you want less headaches and you don't want to get stuck. Go ahead and get it from the top and remove those parts.
Old Aug 28, 2015 | 06:53 AM
njn63's Avatar
The official Honda method is from under the car. For the rest of us plebs that don't have a lift, it's worth the extra couple minutes to pull the intake manifold and work from the top instead of working blind on our back.
Old Aug 28, 2015 | 07:14 AM
HAMZAEP3's Avatar
Thanks mate
Iv heard its Honda method working on Starter Motor from the bottom of the car
working from the top you have to take quite allot of parts off to get to it
Book1483
Honda CR-V & Element
Jan 10, 2018 05:17 PM
nizle144
Nov 24, 2014 12:26 PM
Wasted Dragon
Nov 29, 2012 09:11 AM
itr590
Dec 21, 2010 08:16 AM
