2001 civic 1.7 vtec p1298 p302 p304 p1491
the car wont go faster than 30mph, it shakes at idle, and throttle only responds when pressed slowly while parked.
I have the electric load detector code, two misfire codes, and a temporary egr code. I put new ngk spark plugs.
I had not heard about the "common p1298 code" that these Hondas get, I replace the electric load detector and that code didn't not come back.
car still acting the same.
egr valve has a .5 voltage with ignition on engine off. ive read it should have 1.2 volts
I am getting spark at all the ignition coils, but with the multi meter that reads duty cycle I am getting 98%-100% duty cycle. instructions say it should have 1%-2%
some people have told me to replace the egr other ecm and even catalytic converter might be bad
any ideas??
any ideas??
