Transmission & Drivetrain Gearboxes, Differentials, Clutches
Loose Clutch Spring Rattle????
Old Aug 24, 2015 | 08:12 AM
hondatuner020's Avatar
Default Loose Clutch Spring Rattle????
***Videos fixed
Ok so in this video ( View My Video ) you can hear the metallic jingling rattle which is at idle only when the transmission has stopped spinning. when i push the clutch in at a stop i takes 3-5 seconds for the rattle to begin to make noise. This leads me to believe this it has to be something that only makes noise when the input shaft and clutch disc stop spinning, as when i rev the car the sound stops until it settles at idle again.
I took the clutch out this weekend and the TB and pilot bearings were good and like new and the pressure plate looked good. What i did notice however was how the clutch disc springs were making sooooo much noise in the video below you can here me shake the disc and move the springs. Are these springs supposed to be noisy and could this be the rattle from the first video
View My Video
Clutch is exedy oem replacement for integra type-r (700 miles old) , Flywheel is CC 12lb transmission is 96-97 type-r lsd.
Old Aug 24, 2015 | 09:35 PM
holmesnmanny's Avatar
Default Re: Loose Clutch Spring Rattle????
no video and its not totally clear what is happening from your post
Old Aug 25, 2015 | 04:34 AM
Videos fixed, and it is simple, when the transmission input shaft stops spinning after you push the clutch in a jingling rattle appears from the transmission area. im 90% sure its the clutch disc springs.
Old Aug 26, 2015 | 05:35 PM
So it's either clutch related or tob related. It's even possible one of the bolts has come loose.
Old Aug 28, 2015 | 11:25 AM
SOLVED, i replaced the rattling clutch disc and the noise is gone
m3dia_lab
10
Nov 11, 2004 06:25 PM
vaporboy12
Jun 30, 2004 06:04 AM
HATCHFREEK
Apr 7, 2003 08:40 AM
RacerMike
Jul 22, 2002 07:26 AM
