1990 honda accord
Old Aug 23, 2015 | 07:29 PM
rigger's Avatar
Default 1990 honda accord
I have a 1990 Honda accord and it will go into reverse,2nd and 4th. It will not go into 1st, 3rd and 5th. Any ideas what is going on. I have bleed the slave cylinder and changed the trans oil.
Old Aug 23, 2015 | 09:01 PM
holmesnmanny's Avatar
Default Re: 1990 honda accord
With someone in the car trying to shift into those gears look at the linkage on the top of the tranny and see if anything is binding, loose, or just flat broke.
Old Aug 23, 2015 | 09:14 PM
rigger's Avatar
I replaced the linkage because one of the cables had broke. I measured the distance the book states and it is at the right length.
Old Aug 23, 2015 | 09:57 PM
If you have no issues before the cable broke and now have an issue after replacing them then either the new assembly is not the right one or something is wrong with the installation.
Old Aug 23, 2015 | 10:06 PM
rigger's Avatar
Before linkage was replaced the car would have to run for about 15 minutes before it would go into gear. So that was why I thought maybe the oil needed changed. After that is when found one of the cables broke while trying to shift gears while in the garage.
Brendanherron
Apr 4, 2018 07:25 PM
tietie
Apr 18, 2017 03:15 AM
rhkilgour
Aug 23, 2014 04:44 AM
blurry454
Jun 22, 2009 06:36 PM
