93 Accord ps fluid
Old Aug 22, 2015 | 05:06 AM
My 93 accord's Avatar
Default 93 Accord ps fluid
How would I change out the power steering fluid back to oem honda fluid because I just baught the car and I notice the ps fluid is red instead of light brown?
Old Aug 22, 2015 | 06:13 AM
poorman212's Avatar
Default Re: 93 Accord ps fluid
All depends on how far you want to go?
Me, I'd pinch off the hoses to the res.....remove the res and dump the fluid out. Then I'd clean it as best you can, there is a small screen/filter at the bottom of it - try to get it as clean as you can. Re-install and fill it up with fresh fluid and go from there.
Yes, there are other methods that you could do as well....that is why I stated, it depends on how far you want to go.
Old Aug 22, 2015 | 01:50 PM
holmesnmanny's Avatar
some ps fluid is red it depends what they used .. my old camry used atf fluid
all you do is disconnect the return line and let it drain into a bucket when you start it
sadakoyamahonda
Dec 2, 2018 09:42 AM
Charters
Jul 31, 2017 11:50 AM
Canucksfan101
Feb 2, 2015 10:05 AM
charlescee
Nov 19, 2013 08:15 PM
Dark_Templar
Oct 27, 2008 08:27 PM
