SRS Light.
Old Aug 20, 2015 | 05:39 PM
wwolf771177's Avatar
Default SRS Light.
So my friends a 5th Gen accord has the srs light. I tried the reset but it comes back on, so there's an issue.
My question is can i troubleshoot the srs box without that harness adapter?
Should I check if the ecu throws any type of code? (CEL not on)
Old Aug 29, 2015 | 05:48 AM
Default Re: SRS Light.
Bump
Old Sep 1, 2015 | 03:52 AM
wagon97's Avatar
Yes you have to find correct jump point. I have a 5th gen accord wagon. For me the jump point was under the glove box area. It was a blue plug.
Some models you have to jump two terminals on the OBD2 but not sure which models or years.
You would then have to count the SRS light blinking. You will have to count long blinks then the short blinks to get your code.
You will need the correct code list for your year.
If you search this forum hard you will find all the info. Its here somewhere.
Good Luck
Old Sep 2, 2015 | 08:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Two wire blue connection under/behind the glove box door.
SRS codes can be obnoxious, if you only get a constant blinking beyond any codes in the FAQ then you will need to check the voltage of each circuit per the FSM.
Old Oct 5, 2015 | 09:55 AM
uDraft's Avatar
Mine is on the drivers side wall, near the park brake release (yellow or orange IIRC). The ECU (blue) is under/near the glove box.
xcabin84
Feb 17, 2012 03:43 AM
sc300turbo
May 14, 2008 02:13 PM
nguyennhatquang
Nov 16, 2005 02:32 AM
jAQUAN
Jul 18, 2004 06:36 AM
honda8882
May 14, 2002 10:30 AM
