B16a gear box shift freely in gear still?
Old Aug 20, 2015 | 01:38 PM
Yangpho's Avatar
Default B16a gear box shift freely in gear still?
Hello, I'd just like some answers about my gear box. When driving no matter what gear I am in, I can move shifter side ways as if it were to be in neutral. Doesn't give any problems though. The guy I bought it off said it has a "staged 2 hydraulic clutch".
Old Aug 20, 2015 | 01:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B16a gear box shift freely in gear still?
<p>Your shift linkage bushings have failed. &nbsp;Replace them.</p>
Old Aug 20, 2015 | 05:55 PM
Yangpho's Avatar
Thank you.
Old Aug 20, 2015 | 10:48 PM
frost6's Avatar
I had the same problems, if its not the shift linkages, try tightening the bolts directly under the shifter, for some reason on mine there was some play, tightened it right back up and checked the rest of the linkages so nothing else was wrong but that.
Also another thing that may fail is a pin thats located right by the transmission (known as the "bitch pin" because of the difficulty in taking it out) knock on wood that its not that since if you don't know what you're doing it may be difficult to take out
m.glisson003
Transmission & Drivetrain
May 17, 2013 01:50 PM
9tailsfox
Jan 3, 2011 11:13 AM
Soltis
Acura TL, RL & ZDX
May 26, 2010 08:56 PM
civic92si
Mar 31, 2007 08:34 AM
Understeer
Nov 5, 2002 09:33 AM
