Car Wont Start
Old Aug 20, 2015 | 05:23 AM
TimelessLlama's Avatar
Icon5 Car Wont Start
I drive a 1994 Honda Del Sol. I was pulling out of a parking spot when the car suddenly stalled. I tried turning the car back on and it wouldn't start. I took it back home and I changed the distributor along with the spark plugs. The car still wont turn on. I can hear the pump priming when I turn the key and I can hear the main relay click as well. I disconnected the fuel filter and I verified that there was fuel pressure too. I tried using engine starter fluid to no avail. I believe the car wont start due to no spark but, what else can I check? Where else could the problem be located?
Old Aug 20, 2015 | 06:10 AM
tony_2018's Avatar
Fish Twig
Default Re: Car Wont Start
Is your cel light coming on during startup procedure? Did you clock the distributor correctly before installing?
Old Aug 20, 2015 | 06:33 AM
The check engine light does come on, along with the battery light and the oil pressure light but after about 5 seconds it goes away. How would I know if I clocked the distributor the right way? How would I fix that?
Old Aug 20, 2015 | 06:40 AM
Former User's Avatar
Check for spark.
that747guy
34
Jan 2, 2021 09:27 PM
Benito89
12
Aug 12, 2011 05:14 AM
rich7777
Jan 18, 2010 11:20 AM
tambara
16
Apr 20, 2008 01:01 PM
Zion-I
Jan 24, 2007 07:34 AM
