Questions about my setup..
I have a 93 civic si
I have a whole assembly from a EX
New front rotor
And 02 03 si rear 10.2 4x100
Will i need a bigger MC/BB
I wanna run ITR rear calipers.. if i got them will they bolt up without some tweaking?
Also I have a ASR subframe brace
OEM 22mm rear sway
Fuction7 endlinks.
LCAs are Blox but going to change them for passwordJDM ones
I wonder if I got the ITR lower tie bar and weld it.. with it function properly
New front rotor
OEM 22mm rear sway
Fuction7 endlinks.
Cool Cool Island Breezes. BOY-EE
What are you planning on welding the tie bar to? The ITR subframe has two welded tabs that protrude from the subframe that the bar bolts to.
I would weld those tabs on and bolt the bar down, if you want an ITR tie bar.
B18C1_EK
Feb 28, 2002 12:01 PM
