Modifying Upper Timing Belt Cover
Has anyone removed the lip on the upper timing belt cover so the valve cover no longer needs to be removed to access timing belt? If so, any issues or recommendation. 1999 Civic EX. Thanks in advance.
What are you trying to accomplish by accessing the timing belt with the cover off?
Removing the cover can allow for debris to get inside and possibly destroy the belt.
I see lots of vibration and wobble without the lip. Lots of potential problems.
Better to just get used to using non chlorinated brake cleaner to clean up the gasket and all mating surfaces of the valve cover.
Little more work, a LOT more secure.
Thanks for the feedback. The reason I asked was to eliminate the need to remove the VC to service or inspect any item under the covers (i.e. seals, T-belt, idler) and to reduce contaminating the head with debris with the VC off. I just wanted to eliminate one step in the process. It doesn't sound like many/any have done this.
I just wanna say, I run no upper timing belt cover at all. For atleast 2 years. No problems, whatsoever. Same belt, no vibration, no belt wear or even dirt in the belt compartment. Not telling OP to do this, but for anyone who wanted to go coverless. I never had a problem. 30k miles with no cover.
Stud on the valve cover stripped, my VC is bolted down with 2 bolts and 1 flare nut. It was such a bitch to get it to seal that I totally forgot about the tb cover. And not going to go thru that pita until it leaks again.
I can hear my d16a6 cam a little better though, that and maybe 1 pound weight reduction. Besides that I wouldnt tell anybody to do it.
The cover doesn't change motor vibrations any.
The timing belt is 100% covered (safe).
I have attached a picture (taken from an eBay ad) and colored the removed area in red.
There used to be clear covers you could buy on ebay. Then you didn't have to remove anything and inspect daily if you like.
Not sure if the molds are still for sale or any covers.
Actually just found them on aliexpress, so still can get the SOHC D-series clear cam gear covers from China. Damn, for 96-00 only.
Just compared the 92-95 with the 96-00 SOHC covers and they differ significantly.
Next plan of attack is to compare the back upper cover......
Thanks for all the suggestions. I will post pictures if I decide to modify the cover. Maybe there is a product here. In the 70s, I had a Small Block Chevy with a two piece Mr Gasket timing chain cover that make cam changes very easy. Thanks again for the reply.
trecool44
Feb 3, 2006 06:48 AM
trecool44
Feb 3, 2006 05:47 AM
BlueShadow
Jan 12, 2005 08:38 PM
