Only hot when idle
Old Aug 17, 2015 | 05:41 PM
Brent1204's Avatar
Default Only hot when idle
I have a 1996 Honda civic ex and it only gets hot when ideling as soon as I take off it goes back to normal. The temp. gauge has not went into the red but it gets close. I have changed the radiator, thermostat, and two new hoses. I have also checked the system with the tube and blue liquid to see if maybe a cracked/blown head gasket test showed all to be good. There is no coolant in oil and no white smoke.
Old Aug 17, 2015 | 06:46 PM
Tachi's Avatar
Default Re: Only hot when idle
Is your radiator fan coming on?
Old Aug 17, 2015 | 06:52 PM
Brent1204's Avatar
Yes fan comes on
Old Aug 17, 2015 | 07:12 PM
Tachi's Avatar
Well then I'm stumped. Temps should drop as soon as the fan comes on.
Unless...Have you bled the coolant, and are you sure its topped off?
Old Aug 17, 2015 | 11:26 PM
Alexpro's Avatar
Hard to say but my guess is bad water pump... See if it leak, also make sure you bleed your system using the bleeder screw on the upper radiator hoes at the block.
When bleeding have your heater switch set to HOT position to allow coolant to flow in to your heating core.
Old Aug 18, 2015 | 02:09 PM
excaliburcombo's Avatar
Please also check your radiator fan. sometimes the fan not spinning fast enough.
dhonda00
Jun 11, 2013 04:14 PM
Twistedframe
May 24, 2007 08:26 AM
moosepoop21
May 2, 2006 06:17 PM
dockersguy
Jul 23, 2004 09:01 AM
99 HXagon
Jul 21, 2002 09:13 AM
