94 Accord Brakes
Old Aug 17, 2015 | 10:34 AM
trailshredder's Avatar
Default 94 Accord Brakes
My 94 accord brake pedal goes to the floor to stop it. I have replaced the master cylinder, bench bled, installed, bled all lines until new fluid came out. Still no pedal. It will stop but nearly goes to the floor to do so. Any thoughts?
Old Aug 17, 2015 | 10:43 AM
holmesnmanny's Avatar
Default Re: 94 Accord Brakes
sounds like you need to adjust the master cylinder push rod distance
Old Aug 17, 2015 | 03:03 PM
poorman212's Avatar
What trim level is the car.....or another way, what rear brake set up do you have?
IMHO, if you replaced the booster then I might worry about and push rod adjustments (to master or pedal).....how ever since you only state the mater was replaced.
Be sure the system is/has been properly purged of air.
If you have a rear drum brake set up.......when was the last time yu adjusted the rear brakes and or pulled the drum off and inspected everything and the re-adjusted the rear?
"Holmes" - you know I'm just reading this different and offering another idea.
Old Aug 18, 2015 | 08:20 AM
LX. Rear drums. rears have been adjusted and look good. I bled all bleeders, going from furthest to nearest of the MC. Read that isn't the sequence. What is the sequence and/or does it matter? I bled them all till I had new fluid coming out.
princetom
Suspension & Brakes
Dec 18, 2015 12:43 PM
5rivers
Oct 10, 2015 06:44 AM
76 camaro car
Mar 30, 2014 08:02 AM
accordcle
Sep 18, 2012 08:17 PM
95f22
Jun 27, 2009 02:31 AM
