Suspension & Brakes Theory, alignment, spring rates....
Brakes going to floor after changing master cylinder
Old Aug 13, 2015 | 10:15 AM
Jakroy's Avatar
Default Brakes going to floor after changing master cylinder
I have a 91 accord I changed my master cylinder, my pedal still goes to the floor when the car is on, when it is off I get resistance, I am going to try and bleed the brakes more. I am very new to cars but I have changed pads and a rotor before, the rotor I have on now is bad I'm going to change it when I can but right now I am just wanting to know what could be causing this issue.
Old Aug 13, 2015 | 10:17 AM
burnoutboy's Avatar
The Credible Hulk
Default Re: Brakes going to floor after changing master cylinder
Did you bench bleed the M/C before install? If not take it off and start over.
Old Aug 13, 2015 | 10:29 AM
Jakroy's Avatar
Yeah we did that, it came with the tubes to do it.
Old Aug 13, 2015 | 10:32 AM
burnoutboy's Avatar
The Credible Hulk
Really? And you've bled the brakes at all 4 corners? Did you bleed them in the right order?
Old Aug 13, 2015 | 10:50 AM
Jakroy's Avatar
We just bled them from the master cylinder when we installed the new one, I watched a couple videos on how to do it. There were only 2 places to bleed them that I saw and they were on the m/c
Old Aug 13, 2015 | 10:57 AM
burnoutboy's Avatar
The Credible Hulk
Nope. You bled the master cylinder properly. Now you need to bleed the rest of the braking system. When you unhooked the lines from the MC some fluid likely dripped out leaving an air void in the line.
Old Aug 13, 2015 | 02:22 PM
Jakroy's Avatar
Okay so we have bled the first two and then turned the car on from the m/c we pumped the brake and bled them that way no were about to bleed them from the 3 and 4 from the diagram you sent
Old Aug 14, 2015 | 06:04 AM
Jakroy's Avatar
Okay we have bled the brakes but my dad said we could do it in a different order the back two first then the front two working from back passenger to driver. The brake still goes to the floor
Old Aug 16, 2015 | 08:14 AM
m4xwellmurd3r's Avatar
Hondas are cross linked braking systems. The front left and rear right brakes are one system, and opposite for the others. You have to bleed them in a certain order or else you won't get the air out properly.
Old Aug 16, 2015 | 08:38 AM
phunhaus's Avatar
I would start considering a booster problem.
Why did you replace the master cylinder?
sandjunky
Jul 17, 2010 05:46 AM
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
Allurian
Suspension & Brakes
10
Oct 2, 2008 07:41 PM
y49crxsi
Jul 16, 2004 02:14 PM
from_zer0
Mar 24, 2002 10:29 AM
