Da suspension / Skunk2 / Lower forks need help/advice
Old Aug 13, 2015 | 09:33 AM
BuiltnBought's Avatar
Default Da suspension / Skunk2 / Lower forks need help/advice
Hello HT, I recently purchased a set of Skunk 2 struts for my 92 Integra. Upon install i realized the base of the strut does not fit tight into the fork.
It has way to much gap.
The forks i am using have been laying around for some time, the car has been torn down for about a year now.
Is it possible these forks are off a diffrent chassis, and does it make sense that if i had eg/dc forks that the diameter of the fork would be larger then my DA struts?
I know the diameter of the strut base differs from dc eg/ to DA. However i thought the DA carried the larger diameter strut and fork.
Are my struts wrong, or do i have the wrong front lower forks?
Thank you in advance for any help and input.
Old Aug 13, 2015 | 06:22 PM
B_Swapped93's Avatar
Default Re: Da suspension / Skunk2 / Lower forks need help/advice
EK/DC/EG are wider than EF/DA. someone gave me EF forks for my DC was way too small that's just your issue in reverse. get DA ones from where ever
Old Aug 17, 2015 | 01:46 PM
Thanks brotha, I was really hoping it was that and not the fact I'd got the wrong struts or something. I figured EF/DA would be the larger diameter if anything.
Thanks again
arinaldi
Jul 21, 2009 12:25 PM
GroundZer0 336
Jul 11, 2009 09:15 PM
superhatchbackbros
10
Feb 8, 2008 11:22 PM
Mr. Giggles
Feb 1, 2007 07:47 PM
89dohcEF
Nov 8, 2003 11:58 AM
