rucked radiator bracket
Old Aug 13, 2015 | 07:43 AM
Snailor Built's Avatar
Default rucked radiator bracket
I am currently making a more track oriented civic and finishing up final touches on the radiator. I was curious, those of you have have made or had brackets made for a tucked radiator what are some of the designs you've worked off of?
I am running an All-In half size tucked radiator. So I was thinking about getting a sheet of steel, making a flat plane for it to sit on, and then weld to arms off of the traction bar. I currently am forward facing so I dont have a lower radiator support (lots of room). Now I was thinking, I would probably need two weld two bungs into the bottom of it, get a long enough bolt and washer, run through the bottom and insert a bushing in between right? Thanks in advance for any ideas.
(sorry only decent pic of the bay)
sam000lee
Jun 13, 2015 06:20 AM
kirkland08
Feb 9, 2011 07:43 PM
yz125rider21
15
Jan 7, 2008 11:42 PM
whole9
Jun 9, 2007 08:47 AM
