*H22*Thread size and pitch clutch slave bleeder and mounting bolts?
<p>Hi I'm looking to replace the bleeder screw on my clutch slave as well as get some new mounting bolts. I'm thinking about mounting bolts with a deep 1" head for easier install/uninstall. </p><p>Clutch slave bleeder was rounded off by a shop... go figure. Can't crank it down tight enough.</p><p>Anyone know what type of nylon washer I could put in between over the clutch master rod to sit in between the master boot and rod? To reduce wear from the rod moving in and out of the rubber?</p><p>I can bleed the clutch and even with a brand new braided clutch line direct from the master to the slave I still lose fluid I believe at the boot of the Brand New clutch master, along with the Brand new line that runs from the Reservoir to the master.</p><p>Thanks</p>
a complete replacement slave cylinder is so cheap now that you would be better off just replacing it. you can pick them up for as little as $6 from Rockauto.com. a nicer brand is only $11.
the bleeder screw may be M4. just for the sake of trivia I'll measure up an old one this afternoon to be sure.
krysted9354
Dec 30, 2008 09:19 PM
vi3tromanc3r
Mar 9, 2007 12:56 PM
phantom_sol
Oct 8, 2003 08:14 PM
