Misfiring issues
Old Aug 12, 2015 | 11:25 AM
eh2_y8's Avatar
Default Misfiring issues
00 integra gsr with a constant mis fire. Converted to obd1 ecu (stock) has new distributor coil, head cleaned/resurface, freshly built block from a shop, new injectors. Pulled the plug one by one and the misfire got worse. Any help is appreciated!
Old Aug 12, 2015 | 11:47 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Misfiring issues
Did you set the valve lash?
Mech timing is set correct?
firing order correct?
Which plug had no change when pulled?
Old Aug 12, 2015 | 12:03 PM
eh2_y8's Avatar
Timing is dead on, valve lash was done and all of them had change.
werteg
25
Dec 16, 2010 04:59 AM
stackz
Jan 5, 2007 01:25 PM
NoahSukata
Nov 2, 2005 04:10 PM
tilt
Aug 13, 2003 12:01 PM
