1996 JDM B18C Oxygen Sensor (Which one to use??) *Pics
Old Aug 11, 2015 | 12:56 PM
92-CivicLX's Avatar
Default 1996 JDM B18C Oxygen Sensor (Which one to use??) *Pics
I have a 1996 B18c spec swap in my 1997 Civic LX Sedan. My O2 sensor plastic came unhooked and got burned by my exhaust so I ordered a new one. It didn't fit so I went to the Honda dealership to see if they had an O2 sensor in stock so I could compare it to the new one I had ordered. Come to find out, now I believe it was the downstream O2 sensor that got damaged. All this time, I was thinking it was the upstream since I have it installed before the cat (custom exhaust).
After Popping my hood, I see this isn't even plugged in after all this time. (First Picture). I assume this is the upsteam?
The 2nd picture, the plug you see is the one my O2 sensor was connected to on my exhaust underneath the car.
Does the O2 sensor that's in the 1st picture the only one that's supposed to be installed?? I heard the 96 JDM O2 sensor only utilizes one Oxygen Sensor.
thanks in advance.
-Jeremy
Old Aug 11, 2015 | 09:17 PM
gwh0803's Avatar
Default Re: 1996 JDM B18C Oxygen Sensor (Which one to use??) *Pics
JDM B18C only has 1 O2 sensor upstream at the header since oversea markets have different emission regulations than Japan. Plug the connector in the first picture to the O2 sensor in the header.
Are you running a JDM B18C ecu?
Old Aug 11, 2015 | 09:20 PM
92-CivicLX's Avatar
Yes, I am running the stock JDM p73 ECU. The O2 bong is underneath the car so I just ordered an extender. Thanks for the reply!
Old Aug 13, 2015 | 08:36 AM
94eg!'s Avatar
#1 Super Guy
Loved
O2 setup all depends on what ECU your running. JDM ECU won't look for the 2nd sensor so no worries about the extra plug. Just secure it somewhere so it doesn't get damaged.
Old Aug 13, 2015 | 05:05 PM
92-CivicLX's Avatar
Ok sounds good! I will plug the 2nd hole up with a bolt. I'm glad my 2nd O2 got burned up because I thought that was my primary after all this time. Thanks for your help!
phoshyzzle
Oct 18, 2009 07:52 PM
all_stock
Oct 3, 2003 06:15 PM
Jebus
Mar 21, 2003 02:43 PM
