Are "better" plug wires a good buy?
Old Nov 5, 2002 | 07:52 AM
Drag-On's Avatar
Default Are "better" plug wires a good buy?
question stands above.
some people say they are only for show, others say they are a good upgrade.
what do you think?
Old Nov 5, 2002 | 07:53 AM
RedEK's Avatar
Default Re: Are "better" plug wires a good buy? (Drag-On)
ngk wires
Old Nov 5, 2002 | 07:55 AM
vtec69's Avatar
there was a study a few months ago that stock wires were the best performing out of all of the aftermarket ones
-Brian
Old Nov 5, 2002 | 08:02 AM
B_CRUZ!'s Avatar
Default Re: Are "better" plug wires a good buy? (RedEK)
OEM is fine. If it goes bad, get NGK. YOU WILL NOT GAIN HORSEPOWER BY CHANGING YOUR PLUG WIRES.
Error
Post text cannot contain more than half capital letters. Please revise.
Old Nov 5, 2002 | 08:06 AM
Mojo-Jojo's Avatar
Default Re: Are "better" plug wires a good buy? (Andre_Young)
The reason most people see benefits from putting new plug wires on is because the ones on the car were worn.
Just get the OEM NGK's.
Old Nov 5, 2002 | 08:12 AM
owen_the_soyboy's Avatar
Default Re: Are "better" plug wires a good buy? (Mojo-Jojo)
Old Nov 5, 2002 | 08:17 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Are "better" plug wires a good buy? (owen_the_soyboy)
I don't know why so many people think o.E wires are NGK.
*Maybe* some are, but all the ones I've seen are black Sumitomo wires and not NGK.
Either way, O.E wires are just fine.
Old Nov 5, 2002 | 08:30 AM
BlackDeuceCoupe's Avatar
HT White Ops
...Just get the OEM NGK's...
I wish you bros would quit parroting each others lies. This is a perfect example of the bullsh!t that's being spread around here.
First of all, NGK spark plugs wires are NO different than 99% of the others. Simply put, they are a POS. Magnecor KV85 competition cables are the best spark plug wires made, and you can get them for slightly more than the NGK pretenders. Check this out if you want the truth about spark plug wires:
https://honda-tech.com/zerothread?id=320382
Secondly, OEM WIRES ARE NOT NGK's. OEM wires are made by Sumitomo. Here's a pic of the OEM wires:
I'll bet you boneheads have never even heard of Sumitomo, yet you keep telling everyone to go out and buy them - you say they are the best wires made - and all that other sort of rubbish.
Give it up bishes...
Old Nov 5, 2002 | 08:33 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Are "better" plug wires a good buy? (BlackDeuceCoupe)
Dude I actually beat BDC to a correction!
I already said O.E wires aren't NGK y0!
HT White Ops
Default Re: Are "better" plug wires a good buy? (B18C5-EH2)
I don't know why so many people think o.E wires are NGK...
Heh! Whoops! You beat me to the slapdown...
Old Nov 5, 2002 | 08:50 AM
SprayinCX's Avatar
then which would you say ngk or msd wires both have been around for awhile.
B_CRUZ!'s Avatar
thats also asuming the POS magnecors wont fall apart on you, but thats also asuming u got them to stay on the plugs in the first place....their qualit sux, the boot always pops off the plugs
-akumaY
From my experience, Magnacore sucks. I had them on my 92 SE-R and they tend to pop off of the spark plug and few a few times off of the distributer. and I know I am not the only one that that has happened to.
NGK or OEM =
wow thats the reason why i ngk and OEM. even if you put them on wrong, they still work great
I read that before and yes it even came down to the point where i would zip tie the boots. I don't need to do that with NGK
-Andre_Young
Old Nov 5, 2002 | 11:31 PM
HT White Ops
Hahahaha! You better stick with OEM wires. Those of you that aren't willfully ignorant, get Magnecor's...
Old Nov 5, 2002 | 11:41 PM
mantic6t9's Avatar
I did I have sumitomo tires.
I got some ngks from a friend for $15 so i used them and havn't had any problems yet.
Old Nov 6, 2002 | 12:02 AM
HT White Ops
Default Re: Are "better" plug wires a good buy? (mantic6t9)
How come you didn't buy OEM tires???
Old Nov 6, 2002 | 12:04 AM
mantic6t9's Avatar
Damn you got me
Old Nov 6, 2002 | 12:13 AM
seano's Avatar
"sumitomo tires, and they gotta be run flat"
Old Nov 6, 2002 | 10:02 PM
TakeMeOverThere's Avatar
The best wires money can buy are STOCK, dont waste you money and time STOCK ARE THE BEST, no bullshit
Old Nov 6, 2002 | 10:05 PM
HT White Ops
Default Re: Are "better" plug wires a good buy? (B_Cruz)
thats also asuming the POS magnecors wont fall apart on you... the boot always pops off the plugs -akumaY
From my experience, Magnacore sucks. I had them on my 92 SE-R and they tend to pop off of the spark plug...and I know I am not the only one that that has happened to... thats the reason why i ngk and OEM... and yes it even came down to the point where i would zip tie the boots. -Andre_Young
You know, these motherfuc*ing, lieing, coc*suc*er are really bugging me; so much so, that I went out and pulled my plug wires tonight. Look at the design Honda uses:
First of all, they used a 7-inch long plastic holder that goes inside the spark plug hole. There is a spring-loaded clip inside the holder that 'clamps' itself to the top of the spark plug. Then, there is the lower rubber boot that basically welds itself to the ceramic spark plug body, no matter how much silicone grease you use.
Then, on the valve cover, there is a lip that holds the top of the spark plug holder in place. From my experience, it basically welds itself in place too.
Do these fuc*ing liars think you are so stupid as to believe that 100-dollar Magnecors competition spark plug cables are going to simply pop off the plug, unglue itself from the spark plug body, pop out the valve cover, and come flying out of the 7-inch deep hole? Please! It's a physical impossibility and you know it!
Give it up, bishes...
Old Nov 6, 2002 | 10:37 PM
krazn's Avatar
nobody can argue w/ this man.... you can try... but u will not succeed.
Old Nov 6, 2002 | 10:40 PM
mantic6t9's Avatar
If they are flying out of the holes you:
1.Don't have a spark plug in the head.
2.The spark plug is loose allowing blow by.
3. You are lieing
4.You're and idiot
You choose.
Old Nov 6, 2002 | 10:51 PM
Kamin's Avatar
3. You are lieing
4.You're and idiot
You choose.
well put
i was gonna say the same thing.
if the spark plug is installed its IMPOSSIBLE for that to happen.
Old Nov 7, 2002 | 01:13 PM
B_CRUZ!'s Avatar
I don't know why the **** you think I would lie about shitty *** plug wires.
MAGNACORE IS A PIECE OF **** from my experience.
edit: oh yeah **** you and MAGNACORE....
[Modified by B_Cruz, 2:23 PM 11/7/2002]
Old Nov 7, 2002 | 01:19 PM
B_CRUZ!'s Avatar
I guess MAGNACORE should of used Honda's design
Old Nov 7, 2002 | 01:22 PM
-Whitey-'s Avatar
if you ever get a chance to look at some pro racers plug wires take a look at em i know jojo callos and a few others use stock honda wires just my .02
