PA: Turbo GSR Complete Part Out.
ocation: Lancaster PA
Best Contact - Email - Lax6soccer@yahoo.com
More Pictures are here!! Over 150 pictures
https://www.facebook.com/groups/849130675182061/
Hey Guys. I am looking to part out my 94 Del Sol Turbo.
It has a built B18c Turbo that was tunned by Innovative Motor Works and made 360hp on 20pi.
I have receipts that total well over $8000.
There is over $6000 just into the engine alone.
BAD: It has a spun #2 Rod Bearing.
Background on car:
Owner 1 built car and sold to Owner 2 with 1k miles on build
Owner 2 drove car for two weeks and blew up oil pump.
Owner 2 slapped in 2 stock valves (bent 2 SBI ones), LS oil pump, and put in new bearings.
Owner 2 let car sit for a little under a year
Owner 2 traded car to me not telling me above information.
I drove car 9 miles and spun #2 rod bearing.
I towed car home.
Car has been sitting in garage ever since.
I found all this information through Owner 1 after I found his contact information through the paper work that I had.
I will be selling the head and block first and depending how I feel after that either swapping something else in or parting out the rest of the car. So keep an eye out for other threads or updates to this one.
All parts including fees and shipping unless stated. Will get a quote for buyers that want bigger items shipped.
From what information I can gather from both previous owners the engine build only has about 1,000 miles on it.
PARTS:
Brain Crower Springs and TI Retainers - $250
SOLDBuddy club stage 3 cams - $290SOLD
SOLD Golden Eagle Adjustable Cam Gears - $90 SOLD
SOLD Injector Dynamics 1000cc injectors - $375 SOLD
(Coming with wiring)
SOLDAem Fuel Rail - $125 ( will separate shoot me a offer) SOLD
Aem fuel pressure regulator
Liquid filled pressure gauge
Password JDM Cam Seal - $15 ($10 with bought with something else)
Type-R intake manifold - $120
(Comes with IAC valve)(Ported Throttle body)
SOLDBare Type-R Head - $325 (Shipping not included)SOLD
(No cams, springs, cam seal, or valves)
(HAS - SBI valves guides, 3 angle valve job, mild port, fel-pro valve seals)
Cosmetic head gasket- $40
81.5mm
Pictures coming soon.
B-series Distributor ODB-2 - $80
(Comes with wires)
Pictures Coming Soon.
Type-R Valves - $75
(I was told they were SBI Valves #10435. 2 intake are different and 2 exhaust are different.)
(All are in good condition otherwise)
Valve Cover - $150 SOLD
Powered Coated Blue comes with wire cover.
Hondata 3 Bar Map Sensor - $75SOLD
B-series throttle body 63mm - $45 SOLD
Comes with gasket and TPS.
Keep an eye opening for the following coming soon.
Engine:
B18c Block
Weld in block guard
Wesico Pistons
Eagle Rods
Moroso oil pan - with oil return hole
Turbo Kit:
Turbonetics Turbo
Cast Log Manifold
Turbonectics Blow off valve
Turbonectics Waste Gate
Precision intercooler
Hondata boost controller
4in downpipe
HKS turbo timer
Background on car:
I towed car home.
PARTS:
81.5mm
(Comes with wires)
Type-R Valves - $75
Engine:
B18c Block
Weld in block guard
Wesico Pistons
Eagle Rods
Turbo Kit:
Turbonetics Turbo
Cast Log Manifold
4in downpipe
HKS turbo timer
Last edited by Poppins324; Oct 10, 2015 at 05:55 AM. Reason: Updated pictures. 8-10-15
back to page 1
be sure to check out my other thread for more goodies.
https://honda-tech.com/sale-10/pa%3B...-more-3255852/
bump.
will take tades for the following.
Xbox one, Professional Tools (i.e. snap-on, mac, matco), Shop equipment, home improvement tools
back to the top.
Will be pulling out the following this weekend.
- Hondata S300 ECU
- Comp Clutch Stage V Kit (1,000 miles)
- EG B series axles, like new.
- EG avid stainless B series motor mounts
- Hondata S300 ECU
