Max tire size
Old Aug 9, 2015 | 11:25 AM
raider89's Avatar
Default Max tire size
01 prelude.
i have 215 35 18 found a good price on some 215 45 18s will this be good? Look at some stickies and dont see anything Bout 45
Old Aug 9, 2015 | 12:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Max tire size
The proper size tire for the '01 Prelude using a +2 wheel size change would be a P215/40R18. The tires you had are actually too small (diameter) and throws off your speedometer and may affect ABS operation. The tires you can get a "good deal" on are actually way too tall... and this will increase the chance that you will have rub problems... especially during cornering.
Don't get the wrong size just because it is a "good deal"... get what is right for the car.
Original tire = P205/55R16 = 24.87" tall
Current tire = P215/35R18 = 23.93" tall (essentially 1" shorter than OE) - WRONG
New tire = P215/45R18 = 25.62" (essentially 3/4" taller than OE) - WRONG
Proper "+2" tire = P215/40R18 = 24.77" tall (only 1/10" shorter than OE) - CORRECT
Slightly shorter is usually preferable when the section width is wider to minimize, or even eliminate tire rub.
xero_xero
Dec 30, 2012 08:08 AM
enzozenuni
Jan 29, 2007 10:53 AM
ludewithanh22
Jun 2, 2005 11:04 PM
xdavidx
May 4, 2005 02:57 AM
brian2903
Apr 26, 2004 06:53 PM
