Leaking windscreen washer fluid
I have a 2001 Honda accord LX 245km which is leaking washer fluid. I am not sure if the plastic washer fluid container has a hole in it or its leaking from a lose hose. The washer fluid does come out , so the pump is not at fault. What should i look at. I know to fix this I am going to have to take the front bumper off, but if its something simpler to look at I will try that first.
Thank you in advance
i think you can get to the pump by removing the fender liner above the tire and rotate the tire to get more space, at least thats how i did it in my 94 lx, i dont think theres much difference. check for a loose hose from the pump to the lines that goes to the nozzles.
