I lowered my car a while back and something that has always bugged me is the front seems to be sitting too high for a 2.25" drop....
The back should be a 2.00" drop and I expect the back to sag a little which is fine but does the front look weird to anyone?
and before you say "coilovers" please know that I'm currently saving up for them but it's going to take some time.
Skunk2 springs... yeah, I hate to say it, but that's not surprising. They're known to sag in the rear, and aren't really a great choice for a straight-up spring swap. If you want a more even ride height, you may want to get at least two of the springs replaced (if not all).
Yeah like I said I'm not really worried about the back sagging. I was asking if the front looks normal. It seems more like a 1.25" drop than a 2.25". Maybe it should sit lower?
Are those 15 or 16" wheels? Because it looks normal up front to me.
I'm starting to think maybe spacers would help bring the tire out and fill some of that empty space. Also show more of the top of the tire...
This still isn't going to help with the mismatch height drop. All it's going to do is poke the tire out and cause more stress on your hubs with skunk springs. In worst case, it might cause rubbing because your shocks are blown and cause a blow out.
That would all depend on the size of the spacers and the wheel offset. So yeah running 60mm spacers in the front would be stressful.
If you're running on a full tank that matters too.
Spacers arent going to alter your ride height. I'd think a side by side pic would be more useful.
I'm dropped 4" in the front and 3 in the back. Because I know when I get a full tank the back will settle to about 3.5. Opposed to having a 4" in drop all around, which then I would be 4.5 in back with a full tank, similar to your ride height.
