(IA) FS: 1996 Integra db7 b20b $4000
Old Jul 29, 2015 | 08:49 AM
Android_db8's Avatar
Default (IA) FS: 1996 Integra db7 b20b $4000
$4000
225k miles on body - Clean title
Low mileage JDM b20b high compression swapped (1000 miles since swap)I have spent a lot of time & money in the past year replacing much of the mechanicals and other misc parts on this Integra.
Here's whats new:
NGK blue plugs/wires
Exedy stage 1 clutch
Fidanza 7.5lb flywheel
ARP clutch & flywheel bolts
Tein basics coilovers
Blox front sway bar end links
Blox lower control arms
Blackworks rear subframe brace
Hardrace rear toe kit
L&R Tie rods
L&R CV axles
Steering rack boots
brake rotors
Hawk hps brake pads
Skunk2 intake manifold
Hondata IM gasket
blox extended IM bolts
OEM throttle body gasket
PLM race header (rmf style) & test pipe
DEI titanium wrap
OEM header gasket
Vibrant exhaust
Climate control
JDM folding mirrors
JDM relay & switch
Obd1 ecu
Obd1 jumper harness
Wings west mugen front lip
Innovative rear motor mount
torque mount
spare tire
Mishimoto fan
DS vent
Fuel pressure regulator
starter
power steering pump
BBS wheels w/ good S-drives
battery
The car is plastidipped and looks very good. We put a lot of prep work into it including sanding, cleaning, pre-dip spray, and we used the actually Plasti Dip sprayer kit to apply multiple coats of aluminum dip including glossifier. Original color was silver so it looks good inside & out.
The distributor needs replaced. The engine will misfire occasionally, but once at operating temperature the issue goes away. The transmission has no 4th gear. I am including an extra LS trans w/ the car, but I don't have time right now to swap them myself. I have a new power steering pump, but no belt on it.
If you are looking for a daily driver or a family car I recommend you look somewhere else. This car has a lot of potential, and as it sits it is very loud under WOT, and has an aggressive suspension setup. No AC, cruise, horn, stereo, or airbags. (But I can include some of these things if you prefer) This 4 door is light weight and a ton of fun to drive even with just a bolt on b20.
Link to build: Android's 96 DB7 B20B project & 98 GSR recovery - Page 7 - Team Integra Forums - Team Integra
I am selling only because I have 2 Integra's and I need a truck for work.
Vehicle is located in East Iowa near the Mississippi River 3 hours drive west from Chicago.
Contact: (563) Two75-9758 (text or call)
Sign picture:
Android_db8
Jul 29, 2015 08:45 AM
ZimsSIRunit666
Mar 24, 2010 10:19 PM
Yosshaa
Oct 27, 2009 03:35 PM
SleepingCivic35
Nov 14, 2008 09:24 PM
DA9tegra
Sep 29, 2008 10:18 AM
