Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Honda Accord A/C blowing hot air when Idling
Old Jul 27, 2015 | 07:14 AM
lindsey197122's Avatar
Default 2007 Honda Accord A/C blowing hot air when Idling
My Wife's 2007 Honda Accord VP A/C is blowing hot musty air only when it's idling. If she's driving it's fine. We have already changed out the condenser motor and recharged the system. Does anybody have any other ideas on what might be wrong with it ? Any advice is appreciated.
Old Jul 27, 2015 | 04:15 PM
Lost Again's Avatar
Default Re: 2007 Honda Accord A/C blowing hot air when Idling
Please bear with me as I just want to "check off" a few things and be sure I understand the issue fully.
When the AC is on BOTH fans are running? YES/NO
You say the system was "re-charged" - how did this and what measure was used to recharge it....also can you give some spec's as to where the high and low pressures were and the temp/humidity when those two readings were taken.
Old Jul 28, 2015 | 05:45 PM
4dbull's Avatar
If the cooling returns when you raise the idle speed,then I would be inclined to suspect a vacuum leak or faulty diaphragm,possibly on the door that switches from heat to ac.
rfhjr
Feb 19, 2018 06:37 PM
toughdame59
May 25, 2017 02:32 PM
amitzbhushan13
Jun 16, 2016 03:33 PM
kvnrpp
Honda Civic (2006 - 2015)
Sep 24, 2013 11:40 AM
Xamius
May 16, 2012 12:29 PM
