rebuild b16a jdm need to know what haynes manual to buy for specs.
Hi I'm rebuilding my jdm b16a 2nd Gen.its swapped into my 95integra.i know i need certain torque specs and sequences.i need to know what Haynes manual to buy for this certain motor.i dont want to get the motor back in try to start it and something get messed up all because i used the wrong torque on a main cap bolt lol.
most likely you will need the del sol b16a3 manual. I believe the jdm second gen b16 motor is an OBD1, and the del sol with the b16a3 is also obd1, so everything shuld be off that manual.
Ride on thanks man I appreciate ur help but I'm new to everything man learning as fast as I can but what years del sol Haynes tho I prolly can research it but if u knew would help me alot so I can start searchin for the manual thanks
TypeR0207
Feb 8, 2002 07:08 PM
hb_racer
15
Dec 24, 2001 06:13 AM
