PA FS/FT 94 del Sol. Built B18c Turbo 360HP $5500
Old Jul 25, 2015 | 08:59 AM
Poppins324's Avatar
Default FS/FT 94 del Sol. Built B18c Turbo 360HP $5500
MODS PLEASE CLOSE, PARTING OUT
Best Contact - Email - Lax6soccer@yahoo.com
Price: $5500 obo
Trades - Honda Ruckus or maybe a nice EF sedan.
Partout? - I would be willing to part the engine and turbo kit with the price it right. I currently have an offer for the for car but it is lower then I want.
More Pictures are here!! Over 150 pictures
https://www.facebook.com/groups/849130675182061/
Hey Guys. I am looking to trade or sell my 94 Del Sol Turbo.
It has a built B18c Turbo that was tunned by Innovative Motor Works and made 360hp on 20pi.
I have receipts that total well over $8000.
There is over $6000 just into the engine alone.
BAD: It has a spun #2 Rod Bearing.
Background on car:
Owner 1 built car and sold to Owner 2 with 1k miles on build
Owner 2 drove car for two weeks and blew up oil pump.
Owner 2 slapped in 2 stock valves (bent 2 SBI ones), LS oil pump (needs a type-R), and put in new bearings.
Owner 2 let car sit for a little under a year
Owner 2 trade car to me not telling me above information.
I drove car 9 miles and spun #2 rod bearing.
I towed car home.
Car has been sitting in garage ever since.
I found all this information through Owner 1 after I found his contact information through the paper work that I had.
NEEDS:
New / resurfaced crankshaft
Two SBI dished valves
Type-R oil pump
Main bearings + Rod bearings
Battery
Engine:
B18c Block
Weld in block guard
Wesico Pistons
Eagle Rods
APR Rod bolts
Moroso oil pan - with oil return hole
AVID Solid Motor Mounts
Aluminum Radiator
Pusher Fan
Turbo Kit:
Turbonetics Turbo
Cast Log Manifold
Turbonectics Blow off valve
Turbonectics Waste Gate
Precision intercooler
Hondata boost controller
4in downpipe
Tanabe Medalian downpipe back
HKS turbo timer
Engine Head:
Type-R Head (Port and Polish)
Valve Job
Cosmetic head gasket
Brain Crower Springs and Retainers
Buddy club stage 3 cams
Golden Eagle Adjustable Cam Gears
Hondata 3 bar map sensor
Injector Dynamics 1000cc injectors
Aem Fuel Rail
Aem fuel pressure regulator
Liquid filled pressure gauge
Password JDM Cam Cap
APR head studs (unknown how many times torqued)
65mm throttle body
Type-R intake manifold (Port matched to throttle body)
Tuning:
Hondata S300
Tuned by Innovative motorworks
HP - 360 @20psi
TQ -260
Transmission:
OEM Acura Type-R LSD Transmission (New from Honda)
Competition Stage 5 Clutch
Suspension / Wheels
16in Work Wheels
Tein Coilovers
Adjustable upper control arms
Poly bushings
SPC rear camber kit
Integra Brake swap.
Rear lower control arms
Rear stainless brake lines
Outside:
Pearl White Paint
50/50 taillights
1 piece black headlights
Marker light block off
Carbon Fiber rear trunk lid
Red Honda Front & Rear badges
OEM mudflaps
Shaved Antenna
Inside:
3 gauge setup in center vent. (Only boost gauge works)
Short throw shifter (tall)
2 12in Subs in custom box in trunk
Amp behind passenger seat
NO RADIO
Type-R style shift ****
Extra Parts:
BNIB Blox front upper control arms
Greddy SP2 cat back exhaust
GSR Cams
Old Jul 28, 2015 | 05:24 AM
Poppins324's Avatar
Default Re: FS/FT 94 del Sol. Built B18c Turbo 360HP $5500
Back to page one.
Got some intrest but nothing serious.
Old Aug 1, 2015 | 07:18 PM
Poppins324's Avatar
Back to page one.
Will accept other trades as well.
Maybe EM1s, Trucks, if you cut trees down for a living Ill give you the car for some tree work.
Old Aug 9, 2015 | 06:47 PM
Poppins324's Avatar
MODS PLEASE CLOSE PARTING OUT.
Poppins324
Oct 12, 2015 04:51 PM
delslow2
May 13, 2011 06:08 AM
BUCK_NASTY
Oct 20, 2007 05:36 PM
