Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Accord right rear disk brake wear
Old Jul 24, 2015 | 12:09 PM
Jacobsmail's Avatar
Default Accord right rear disk brake wear
Second time I have had uneven read pad wear on Accord 07 4 cyl, 60K miles. Right side worn out, left side only 50%. Pads wearing evenly - Right inner and outer pads both at 5%, left rear inner and outer both at 50%. Checked pins, round in top, slotted in bottom, both move freely, well lubricated. Piston moving freely both with brake pedal and turning via slotted face, in or out. Fluid clear and bleeds easily. Brakes smooth, no judder. Relaxed hand brake at back of console last time, made no difference in wear.
After new pads, disks have equal resistance to turning (spinning wheel with car off ground) side to side. Hand brake releases equally, same resistance, side to side. Running out of ideas, unless it is related to ABS.
Any thoughts out there? Only getting some 8K per right rear side pads. Car breaks fine, no symptoms, front pads go 20K, no problem, only the right rear is an issue.
Thanks,
Jacobsmail
mtucker
Sep 11, 2017 12:09 PM
ariee29
May 16, 2012 07:56 AM
stevescivic
31
Jul 17, 2011 10:48 PM
AZ_Jim
Nov 22, 2005 08:23 AM
