Suspension & Brakes Theory, alignment, spring rates....
Race valved Koni Yellows, bump stop
Old Jul 23, 2015 | 09:44 AM
43!'s Avatar
43!
Default Race valved Koni Yellows, bump stop
Are you suppose to cut the bump stops provided by Koni in half or leave alone when installing the Koni/Gc setup. Searched, couldnt find a straight answer. Thanks.
Old Jul 23, 2015 | 04:19 PM
Atomic1's Avatar
Default Re: Race valved Koni Yellows, bump stop
Are you talking about bump stops provided by GC? If so, those would already be shorter than stock, so no, you wouldn't want to cut those down any further. If you're talking about stock length bump stops, I would cut them down to give you as much true shock travel without any influence of the bumpstop.....one of the reasons for the shorter shock body.
Old Jul 23, 2015 | 05:47 PM
43!'s Avatar
43!
The bump stops came from Koni. I dont have the stock to compare.
Old Jul 24, 2015 | 01:25 AM
kristo's Avatar
Loved
Depends on the amount of free travel the shock has with the bumpstops.
http://www.koniracing.com/bumpstops.cfm
Old Jul 24, 2015 | 09:43 AM
TunerN00b's Avatar
That's not quite right.
If you want the bumpstop to be functional, you need to keep at least enough such that the bumpstop fully compresses before the shock (or any other part) actually bottoms out. That is the point of a bumpstop, to be the part that bottoms out and prevents damage to other parts. Anything longer than that is suspension tuning and up the the driver to determine.
Old Jul 24, 2015 | 11:18 AM
kristo's Avatar
Loved
Good pointing out
ProPartsUSA
Jul 17, 2013 03:18 PM
realistpnoy
Jul 7, 2013 04:03 PM
hawaiieg6
Suspension & Brakes
Aug 11, 2009 05:47 PM
DLudist
Suspension & Brakes
20
Mar 2, 2006 10:50 AM
