my 1996 accord build questons
okay question i have a stock 96 accord lx non vtec pretty sure i am OBD2,and was wondering if this motor is fairly easy install?Also wasnt the 1996 accord EX a vtec model (so in theory i can put an EX ecu in my lx and run a the motor below?) without too much of a headache?
JDM 94-97 Honda Accord LX DX F22B 2.2L SOHC VTEC Engine F22B1 F22B2
Yes you can install it into the LX.
Yes you can use the correct PCM for the B1 in your LX.
You will need to change/add wiring(or change harness) for the VTEC operation.
If you are going to go threw the trouble of doing a Swap why not go the F23 route? Or if your budget is a bit larger, an H22 would be a great swap? Both of these engines are pretty much plug and play with your chassis. The H22 requiring slight mount modifications and a hard to find ECU. But a custom tuned ECU is easy enough to find.
Just putting that out there in case you want more power!
okay so after some looking around i think im going to go the h22 route,does anyone know a link to a step by step swap guide in a 96 accord?and maybe a prats list if possible please and ty in advance
Look up building a G22 or G23...
from what i read, it can be done for just a little more then a h22 swap and with a lot more power
Search and you will see
The cheaper budget G22/23 hybrid builds rarely work out. The ones that do end up being reliable. Also end up being more expensive then an H22 swap with cams and a header.
The builds that you see where a G23 makes more power than an H22 are not cheap. I have see some people list them at around $1,800 for 200-220whp. That is the parts only cost, without labour or machine shop costs. So the only way to make it cheaper is if you can hone the block and do all the engine building yourself. And you still only end up with the same WHP as a stock H22A7. Buying used parts to save money doesn't always work in the long run. Some of those used parts will require some re-conditioning $$$$.
Just putting that out there!
I know of like *one* guy that did it and posted on here.
The H22 is infinitely cheaper and was actually designed to work that way instead of some cobbled together mismatch of parts.
