94 civic hatchback stalls
Old Jul 21, 2015 | 10:32 AM
banilejo's Avatar
Default 94 civic hatchback stalls
Need help with 94 civic hatchback
My car stall turn off in a red light then turns on a check engine and it drives heavy when I push da pedal to go fast it dosent want to change gears but then it does..is it the cat or the map sensor..
Old Jul 21, 2015 | 11:10 AM
Former User's Avatar
Default re: 94 civic hatchback stalls
Pull the CEL codes and post them.
Bone stock 94 Civic? What engine?
Old Jul 21, 2015 | 11:36 AM
JDM motor import's Avatar
Default Re: 94 civic hatchback stalls
+1 for pulling the code
It could be a map sensor issue or a vacuum leak somewhere and its causing it to stall out?
Old Jul 22, 2015 | 04:49 AM
banilejo's Avatar
How can I check it for leak is a obd1 n autozone cant check the code where can I take it to check the code ...the light ce light turns on then after I turn of the car fo like two hours ce light is off never comes on untill I ride the car for at least 20 minutes or untill it gets hot ce pops on n car drives heavy loud sound off the muffler like if is da cat
Old Jul 22, 2015 | 06:03 AM
กก4drWHORE!!'s Avatar
Hi Banilejo,
You can used this write up to pull the CEL codes
https://honda-tech.com/honda-civic-d...lists-1901557/
Old Jul 22, 2015 | 08:30 AM
banilejo's Avatar
Thanks ama try it I let u know what code it is
Old Jul 22, 2015 | 10:21 AM
banilejo's Avatar
Ok I did it but it gave me 4 fast flashes Whats that code 4 small fast flashes
Old Jul 22, 2015 | 10:23 AM
egsleepercivic's Avatar
4 CKP - crank position sensor
Old Jul 22, 2015 | 11:06 AM
banilejo's Avatar
Kool thanks guys one oter thing where is located and can I fix it my self
Old Jul 22, 2015 | 11:18 AM
Reset ECU to see if code returns.
If so, Ohm test the two CKP sensor wires from the ECU connector. Be prepared that there may be an intermittent open in one of the CKP wires, typically a bad connection at a connector.
Old Jul 22, 2015 | 11:23 AM
Here is a write up on how to test it.
https://honda-tech.com/honda-civic-d...ic-si-2983767/
edit: Looks like Ron was the one helping on the other thread.
Argenis 2524
Jan 12, 2016 11:10 PM
b16vt3c
Feb 5, 2009 06:05 AM
CIVIC dude
Jul 21, 2005 08:35 AM
Hatch It
Oct 25, 2004 06:15 PM
