EF CRX (kswap) Fuel Starvation issues
Old Jul 20, 2015 | 08:38 PM
dibigman's Avatar
Default EF CRX (kswap) Fuel Starvation issues
Hey i have a CRX Kswap
Makes good power and all on the dyno
but once you go to the track, if you launch on the slicks you will notice/hear the engine break up for like a second then revs clean again.
We already did some modifications to the old tank to make it work with this fuel injected application but it still hasnt fully solved the problem.
I was able to launch in 2nd gear and got a 12.7 time slip.
It was a semi-clean run cuz it allows the engine to build power then engage vtec, instead of the sudden blast from 1st gear.
Is there a solution to this apart from a Fuel Cell?
Im also hearing Ek gas tanks can fit the crx. is this true?
Old Jul 21, 2015 | 05:08 AM
v4lu3s's Avatar
RTFM
Default Re: EF CRX (kswap) Fuel Starvation issues
how much fuel is in your tank at the track?
B_Turtle
Jan 21, 2015 11:26 AM
s-power
Aug 9, 2008 05:08 PM
Rene M
19
Apr 2, 2008 08:05 PM
CHRIS 1.8
Apr 5, 2004 05:20 PM
