95 Civic - Fuel Pump Wont Prime
Old Jul 19, 2015 | 12:02 PM
dcrppf's Avatar
Default 95 Civic - Fuel Pump Wont Prime
Hello everyone, I am new here but have a 95 Civic EX as my daily driver. It is completely bone stock and recently I started having problems with the car starting. I would listen for the fuel pump to prime, sometimes it would take a few seconds after turning the key, sometimes I had to turn the key a few times before it would prime. But once it primed, it started right up and ran great. This continued for several months and then I researched and bought a new Main Relay. The new relay gave me the same exact symptoms. Just this weekend, the pump stopped priming at all.
So troubleshooting, I thought maybe the pump went bad or the wiring was bad. I pulled the fuel pump out, jumped it to the battery, and it still fires up, so I know its good. I plugged a test light into the electrical connectors and got nothing. When I plug the test light into the main relay wiring harness, following the diagram below, I had power to pin 1 for the battery and pin 5 for the ignition. None of the other pins had power, even with the key on or cranking. I read other threads and tested the fuses 24 & 31 and both were good.
Can anybody help me out please? Thanks in advance.
Old Jul 19, 2015 | 12:08 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 95 Civic - Fuel Pump Wont Prime
When the fuel pump doesn't prime, does the CEL come on for ~2 seconds then turn off? Check and clean your thermostat ground.
Old Jul 19, 2015 | 12:18 PM
dcrppf's Avatar
The CEL does not come on at all. Forgot to mention that I already cleaned the thermostat ground. Seemed fine, but I cleaned it up anyways.
Old Jul 19, 2015 | 12:35 PM
NotARaCist's Avatar
It doesn't come on, even when the pump primes? Remove your cluster and replace the bulb.
With the key turned OFF, you should have voltage at pin 1, and only pin 1. With the key turned to ON(II), you should have voltage at 1 and 5 (as well as others, but let's stick with those two for now). Do you have voltage at 1 with the key off? Do you have voltage at 1 and 5 with the key to ON(II)?
Old Jul 19, 2015 | 12:53 PM
delsolintegra's Avatar
Could be the ECU when the capacitors in the fuel pump priming circuit fail.
Common problem.
Borrow a known good ecu from somebody with a 93 - 95 civic for a test (P-28).
Check junk yards if you need a replacement about $125.
Old Jul 19, 2015 | 12:59 PM
dcrppf's Avatar
Aw man, you are adding to my list! Haha jk, I will do that sometime after I get it running again.
Just checked again, I only have power to pin 1 while key is off. When key is turned to ON(II) I have power to 1 & 5 but no others. Next step?
Old Jul 19, 2015 | 01:10 PM
dcrppf's Avatar
Common problem.
Ummm . . . I dont know anybody with a car like this. Still a little new to my area. Is there any way to test the ECU? I pulled it out just to look at it today, it was clean and dry and everything looked good, but obviously that doesnt mean that it works.
Old Jul 19, 2015 | 01:13 PM
eghatch9295's Avatar
Stancetard Hate Monger
no burnt spots or corrosion or leaky capacitors= usually good. crack open the relay and look for burn marks/cracked solder joints.
Old Jul 19, 2015 | 01:19 PM
dcrppf's Avatar
When I looked at it there didnt seem to be anything wrong. All solder joints were clean, no cracks. I know they are notorious for going bad at the solder joint, but when I put a new one in, I still had the same problem. Plus with not having power at the wiring harness, I thought that meant that my problem was somewhere besides the relay switch.
Old Jul 19, 2015 | 01:25 PM
time to test your ignition switch, in that case.
Old Jul 19, 2015 | 01:27 PM
NotARaCist's Avatar
So you have power going in at 5, but not coming out at 8? That's indicative of a relay failure. Set your voltmeter test for resistance, and test between 5 and 8. What reading do you get?
If you're getting voltage at 5, then his ignition switch is fine.
Old Jul 20, 2015 | 05:05 PM
dcrppf's Avatar
Ok, so my battery died yesterday so I had to throw it on the charger overnight. After work I checked the car again, and when I plugged in the relay harness again I turned the key a few times and then the pump primed. The car runs now, but I know its only intermittent. Now I have power to pins 1, 3, & 5. With the key on, but no others. I didnt test resistance since it actually worked this time.
What do I do now? Can I still figure out what is wrong when it is actually working?
Old Jul 20, 2015 | 05:10 PM
sounds like a loose connection somewhere if plugging things in/messing with the battery made it work
Old Jul 20, 2015 | 05:14 PM
dcrppf's Avatar
Well really its been an intermittent problem for the last month. Sometimes when I turn the key it wont prime, but after a few turns it will. Also the few times where it wouldnt start at all, I would come back after 8 hours and it would start right up. I have no idea what to do now.
Old Jul 21, 2015 | 05:34 AM
dcrppf's Avatar
So of course when I went to my car this morning, the pump did not prime and it wouldnt start. I didnt have any time to troubleshoot before work, but when I get home I am going to mess with wiring and see if there is a loose connection or something.
Old Jul 21, 2015 | 06:54 AM
I still say ECU. Bad capacitors don't always appear to be burnt or blistered.
My bad P28 ECU the capacitors didn't look bad.
If the weather was warm and dry the pump may prime and the car would start.
If it was a rainy or just humid day (Florida), no prime, no start.
These ECU's are 20 years old now. Heat and humidity take a toll on electronics.
Old Jul 21, 2015 | 07:03 AM
Former User's Avatar
I still say ECU.
Probably
Old Jul 21, 2015 | 10:58 AM
dcrppf's Avatar
So I will check a local junkyard to see if I can find another ECU for a 93-95. Is there any other recommendations on where to buy one and how much it would cost?
Old Jul 21, 2015 | 11:08 AM
Also make a WTB post in the FS/WTB sticky.
Old Jul 21, 2015 | 04:47 PM
dcrppf's Avatar
So after checking this out again, I have noticed that whenever I put my test light on terminal 8 it engages the fuel pump. I guess because the test light is grounded? Im terrible with electronics . . .
Old Jul 21, 2015 | 05:00 PM
^Strengthens idea that ECU is bad.
Old Jul 25, 2015 | 04:09 PM
dcrppf's Avatar
All right guys, I am back at this again. I went to a junk yard today and got another ECM out of a 95 Civic to try. I have plugged it in and now the fuel pump is priming consistently every time and it engaging as soon as I turn the key. Success right?? Well apparently there is another problem now as the car still wont start. It will crank, so I loosened the bolt at the fuel filter and gas starting coming out, so that tells me I do have fuel pressure. And I just pulled all of the spark plugs and checked each one for spark. So I have fuel & spark, and the engine is turning over. Now I dont know what to check.
Old Jul 25, 2015 | 05:41 PM
Install a new properly gapped spark plug into a disconnected to plug wire and ground the plug threads firmly on the valve cover. What color is spark? It should be bright white.
CEL codes?
Old Jul 25, 2015 | 07:05 PM
dcrppf's Avatar
OK I will give that a shot. I did that with the existing plugs, but obviously they were older and im not sure if they were gapped properly. They looked like a yellow spark.
CEL codes?
Well I think we determined that my CEL light is burnt out, so I still dont know if it has any codes or not. I have an OBDII scanner, but Im pretty sure this is OBDI. I just found the post on how to flash the codes so I will give it a try.
Old Jul 25, 2015 | 09:11 PM
Swap one of the other working cluster warning lights into the CEL slot to pull the codes.
