NGK G-Powered Spark Plugs Mistakingly gapped With Coin Tool
Old Jul 19, 2015 | 05:46 AM
Jimi Hondrix's Avatar
Default NGK G-Powered Spark Plugs Mistakingly gapped With Coin Tool
1998 Civic EX stock d16y8, A/T. 149K miles.
I purchased NGK G-powered spark plugs yesterday and gapped them at .044 with a coin style gap tool. Today I remembered that I should have used a wire type gap tool that won't damage the plug's platinum tips. I used a small amount of anti-seize on plug threads, synthetic dielectric grease on tips/boots and torqued them all to 13 ft.lbs.
Seems to run better than it did with previous plugs (no misfires, just aged). I just hope I didn't damage the tips.. Will using a coin style always damage tips or just a possibility of damaging tips?
As a side note the factory gap on these new spark plugs was set at .038
Old Jul 19, 2015 | 10:24 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: NGK G-Powered Spark Plugs Mistakingly gapped With Coin Tool
I'd hazard a guess as possibly damage. The platinum tips are rather small. I'm sure you will find out soon enough as the tip goes through it's heat cycling repeatedly and the wear process.
Also on the older honda's, the v-power with the much larger tip is what is recommended/used stock typically so those are gapped to the .043" as required.
The platinum aren't recommended until later models and the gap changed so stock gap would not be .043" as you found. Instead the 0.038" is for the cars that recommend/require the more expensive platinum plugs.
From everything I've seen, there isn't any benefit with going with the platinum plugs over v-power in these older civics.
Old Jul 19, 2015 | 11:04 AM
These: NGK G Power Spark Plug 7098: Advance Auto Parts
They were out of stock on V-power and weren't much more in price so that's why I purchased them.
I intend to call NGK and ask a technician about using a coin gapper.
Old Jul 19, 2015 | 11:28 AM
TheShodan's Avatar
Moderator
I've used a coin gapper for over 25 years on v-power and even iridium. I'm sure you're fine.
Old Jul 19, 2015 | 04:12 PM
I hope so.. thank you both for your responses.
Old Jul 19, 2015 | 04:28 PM
98civdx's Avatar
Master Detailer
That is the only style I've ever used in my life.
Old Jul 19, 2015 | 04:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
+1. Always used a coin gapper, never once had a problem.
Old Jul 19, 2015 | 05:22 PM
This is what raised my concern:
mickey513
Jun 19, 2014 08:38 PM
skinney6
Aug 26, 2012 12:13 PM
Rob.
May 6, 2009 01:31 PM
