2002 accord issues and questions
Old Jul 17, 2015 | 07:37 PM
Silveraccord02's Avatar
Default 2002 accord issues and questions
Hey guys. I seem to be having a few issues I'm hoping someone can shed some light for me on. Have an 02 accord that has had the check engine light on since I bought it and the code its throwing is p0325, knock sensor. The light used to go off and on until I replaced the sensor and now it just stays on constantly. I understand what the sensor does and it's possible I bought a bad one? I'm thinking of buying another sensor and replacing again but they're pretty expensive and I'm not used to working on Hondas so I'm looking for advice. Thanks in advance.
Old Jul 18, 2015 | 01:09 AM
tim73's Avatar
Default Re: 2002 accord issues and questions
I would suspect the wiring. Use you volt meter on ohms, and check the wiring back to the ECM. Also, check your reference voltage to the sensor, should read 5V when the key is on, and the sensor is unplugged.
Old Jul 18, 2015 | 02:13 AM
Yea think that's my next step. I've read bad ecu can be suspect too. SRS light on too. Wonder if it's all tied in together through ecu. Are they hard to change or do I need certified obd I I tech?
Old Jul 18, 2015 | 08:05 AM
Lost Again's Avatar
Do what? A 5v ref voltage.......please explain more
wade9233
Jun 15, 2013 04:17 AM
wade9233
Jun 14, 2013 06:20 AM
r.etheridge
Feb 13, 2011 02:59 AM
mayflower
Nov 18, 2005 05:33 PM
hw3679
Jun 26, 2004 06:27 AM
