Transmission & Drivetrain Gearboxes, Differentials, Clutches
2001 Acura CL Transmission
Old Jul 17, 2015 | 06:03 PM
Cody97's Avatar
Default 2001 Acura CL Transmission
My transmission started acting really bad and slipping out of gear and i got the code
P0740 - torque converter clutch circuit / open
P0730 - Incorrect gear ratio
P0780 - shift error
P1750 - manufacturing control
P1740 - manufacturing control
I please don't want one worded answers because i know the transmission is messed up i just need to know the fixed.
Old Jul 21, 2015 | 02:23 AM
slowcivic2k's Avatar
Default Re: 2001 Acura CL Transmission
The codes you describe, without any other information provided by you, point to clutch material blocking the valve body filters leading to reduced fluid flow. This will cause slippage or complete failure of specific circuits. Oil pump output (due to a worn out pump or clogged oil filter) is also suspect.
If you want more information, tell us what you drive, when this problem started, and so forth. You need to do more than vent on a forum to attract legitimate attention.
Civic082382
Honda Civic (2001 - 2005)
Sep 10, 2013 01:48 PM
cj90si
May 19, 2011 05:02 AM
chatman_55
Feb 1, 2008 11:58 PM
misoshiru_akira
Feb 26, 2007 06:29 PM
Mark
Jun 18, 2003 08:34 AM
