Who has installed thier Action clutches??
Have any of you guys installed yours in a cable tranny setup? Some of us don't have the hydraulic assistance of the newer cars.
Thanks,
Sonny
Thanks,
Sonny
Thanks,
Sonny
Thanks,
Sonny
A quick drive through the local streets, and your used to it already
Getting out of the drive way the first time was interesting though
How stiff is it and how does it grab?? What model are you guys using?
Yup....
You have an Action disk with a ACT pressure plate, no?
I have the Action dual diaphram pressure plate and action metallic disk. It looks like it's gonna be a leg workout.
Sonny
I have the Action 6-puck sprung sintered iron disc mated to the ACT HD pressure plate.
Feels ok, and is holding the 207lb/ft (at flywheel) on my Y8 motor just fine!
if you guys had to choose between a ACT or ACTION CLUTCH which one would you get...(for street/racing use no 6 puck or 4 puck)
i got the 2MD..did any of you guys had chattering sounds for a while?
i got chattering sounds around 750 to 1500 miles..but its gone now..
like it chatters when i downshift
the MD kits come in sprung and unsprung discs.
1MD has a choice of a sprung puck disc or solid puck disc
2MD is the same but with a dual diaphragm pressure plate
the KS kits are same choice of pressure plates as the MD's but it is a KEVLAR full face disc.
Yup....
Bryson:
Sonny
Bryson:
Sonny
I'm using the Exedy Pressure plate (same torque capacity as a heavy duty ACT.) with the action 6 puck metallic disc.
Works marvelously
Y r u guys using another company's pressure plate and using the action disk?? What is wrong with using the action pressure plate?
