Ej1_Civic's all motor 86.5x98 2.3 Litre Progress Build
Old Jul 16, 2015 | 06:31 PM
ej1_civic's Avatar
Default Ej1_Civic's all motor 86.5x98 2.3 Litre Progress Build
This B-series all motor build it's still in the works hopefully coming out 2017.
Head
RLZ B16 head outlaw port CNC
5 angle valve intake
4 angle valve exhaust
Ferrea valve spring 100LBS / Ferrea titanium retainer
Ferrea 6000 valves
Skunk2 pro3 camshaft going to lock vtec
Golden eagle cam gears
Skunk2 ultra race 4 piston Cnc intake manifold/2L spacer
90mm throttle body
4 inch intake pipe with 4 inch velocity stack
Header (Don’t know yet)
Block
B18c Golden eagle sleeved block 86.5 bore
Golden eagle 86.5 head gasket
Arp main studs/line bore
JRE 98mm (3.858in) Stroke Crank
Custom Ross Racing Pistons 3.406 bore 15.8:1
Chromoly I-Beam Rods
Cunningham rod bolts
ACL Race Bearing
Arp head studs
Golden eagle oil plugs
Oem gsr water pump/oil pump
Tran
B16 Lsd tran
Comp twin disc
S300 ecu
Old Jul 16, 2015 | 06:38 PM
DC-2uned's Avatar
Default re: Ej1_Civic's all motor 86.5x98 2.3 Litre Progress Build
Sounds good
Any pics of current status?
What car is it going in?
Old Jul 16, 2015 | 06:52 PM
ej1_civic's Avatar
Going into my 95 civic coupe
Old Jul 16, 2015 | 06:56 PM
ej1_civic's Avatar
Motor is at my buddy he doing all machining right now.
Old Jul 16, 2015 | 07:21 PM
43!'s Avatar
43!
Beast
Old Jul 16, 2015 | 09:40 PM
koczeka's Avatar
I ran 86.5mm and it's hard to keep head gasket seal.
Old Jul 16, 2015 | 09:47 PM
ej1_civic's Avatar
What was your piston to deck?
Old Jul 18, 2015 | 09:41 PM
ej1_civic's Avatar
Old Jul 18, 2015 | 10:30 PM
DC-2uned's Avatar
Those ports look huge, what kinda cfm does an RLZ outlaw head flow on a flow bench?
Old Jul 18, 2015 | 10:47 PM
ej1_civic's Avatar
When I bought the head the guy I bought it from lost the paper work so I haven't have time to put it on the bench yet.
Old Jul 19, 2015 | 04:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Those are H22 retainers you have pictured... they have a .060" increase in install height over the standard Crower "B" series retainer. If you have "B" series springs, this would change (reduce) your spring rates and alter the spring coil bind point.
As stated above, bores that large make head gasket sealing unbelievably difficult. Good luck.
Old Jul 19, 2015 | 07:23 PM
ej1_civic's Avatar
Retainer are for b-series and h22
Old Jul 20, 2015 | 02:02 PM
Maluko's Avatar
Beast!
Old Jul 20, 2015 | 04:19 PM
DDTECH's Avatar
Its absolutely pointless to lock a 3 Lobe camshaft.
Run a 1 lobe camshaft, if you're going to lock vtec that away you can take advantage of the less rotating mass and actually gain something with locking vtec.
Old Jul 20, 2015 | 10:24 PM
ej1_civic's Avatar
Thanks for the advice DD
Old Jul 20, 2015 | 10:31 PM
ej1_civic's Avatar
Block just came back from the machine shop from milling the deck.
Old Jul 21, 2015 | 04:00 AM
PyroProblem's Avatar
Gonna be a monster all motor build once things get all setup.
Are you planning on o-ringing the head?
Good luck with the build!
Old Jul 21, 2015 | 04:39 AM
ej1_civic's Avatar
No o-ring and thanks...
Old Jul 21, 2015 | 11:24 AM
slowsleeper's Avatar
Really well thought out build Sou, Pat had mentioned it to me and its nice to see the build progress! Excited to see it run!
Old Jul 21, 2015 | 11:38 AM
Charlie Moua's Avatar
very nice mang!
Old Jul 21, 2015 | 12:35 PM
93egSLEEPER's Avatar
Going to be an impressive build. I love big motors.
What are you guessing the compression to be at?
Old Jul 21, 2015 | 04:58 PM
ej1_civic's Avatar
Thanks guys someone in Mn had to step it up lol...
Compression? Idk yet have to wait until moror is built.
Old Jul 21, 2015 | 08:07 PM
UncleD's Avatar
Questioning the VT choice here. S2 XP's should probably be used don't you think?
Old Aug 6, 2015 | 09:05 PM
ej1_civic's Avatar
Should be fine
Old Aug 6, 2015 | 10:55 PM
sr20paisa's Avatar
2.3 b-series...................gawd damn i can't wait to hear the idle, it's gonna be mean old floor-shaker, cool build keep it coming
