DOHC ZC HELP!!!
Hello peeps! i need your help because i am stumped -_-
I have dohc zc out of crx si in my 1991 honda civic hatch
just about a few weeks ago i replaced the head gasket.
after replacing the gasket my buddy/mechanic made me a harness because the injector wiring was horribly weak! very brittle wires. once removin the original harness ( the battery was not disconnected ) and connected the new harness the car would not start! o_o i replaced the fuse box in the engine bay and even tried a new main relay. i also checked the timing of the car. the ecu is throwing codes 6 & 10. would these codes make the car not start? could anyone suggest what i could check on the car? suggest replacing?? anything could help please i am stumped and i need my car for work!! i am tired of riding my bike to work!!! D:
Does the engine have spark or is it completly dead? Does it crank?
Your problem could be anything now since you went replacing things like the fuse box ect when you diddnt know the original problem..
Your codes are for the water temp sensor and Intake temp sensor. Check those sensors and make sure there pluged in. And yes those codes can cause you not to start the engine. The water temp should be on the side of the head and the iat should be on the intake arm tube or the intake manifold. Im not to familiar with a d series even though i have a civic myself lol.
