Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Possible Clogged Cat...
Old Jul 13, 2015 | 06:06 PM
prodjay10's Avatar
Default Possible Clogged Cat...
2004 Civic 1.7L Auto
Was overheating on me after a front end collision. After some time I figured out it was a cracked radiator. Fixed that and it works great.
After a few months my gas mileage started to suffer. I used to get 39 to 40 mpg on long trips now I get 33 pretty consistently on those same trips.
I've done a tuneup (spark plugs, oil change, air filter), timing belt, checked tire pressure, and it's still low gas mileage.
No power loss, runs and starts fine, no codes but the cat is right behind the radiator. What are the chances the cat is partially clogged? Maybe low flow at high speeds...
Old Jul 14, 2015 | 12:21 PM
chaplyn's Avatar
Default Re: Possible Clogged Cat...
Doubt it is a clogged cat, if so I expect you would notice a loss of power. Did you check the timing with a timing light after changing the timing belt?
Old Jul 14, 2015 | 02:15 PM
prodjay10's Avatar
I haven't but all the maintenance stuff was done after loss of mpg.
Old Jul 27, 2015 | 11:38 AM
gadfly's Avatar
What is the mileage on this car? If it has over 125k you might want to consider changing the upstream Oxygen sensor.
A malfunctioning sensor doesn't always trigger a check-engine light (at least it didn't for me) and could me causing the engine to run rich (i.e. too much fuel in the air/fuel mixture). This would explain why you might have a fine level of performance but bad gas mileage.
Old Jul 28, 2015 | 09:43 AM
Curiouz_G's Avatar
Ding ding ding. Next cheapest fix after the 02 sensor is grabbing a test pipe.
Whiteonblackej
Jul 29, 2016 08:51 AM
KansasKev
11
Nov 30, 2008 05:10 PM
serious
Aug 5, 2004 09:25 AM
Splangtastic
Jun 19, 2003 01:30 PM
CivicEK.PDX
Mar 17, 2003 08:17 PM
