Help!!! D series to b series. Won't run
Old Jul 13, 2015 | 03:53 PM
Lou1267's Avatar
Default Help!!! D series to b series. Won't run
Hi
My son recently had the idea to put a 2000 b16 Acura manual motor into his 98 d series civic automatic. My son has no previous mechanical experience but his friend who gave him the motor told him it's a piece of cake. Well 3 wks later the engine is in and fired but barely idles and won't rev. As soon as I push the throttle it drops and wants to stall. So we got the recamended p75 computer and step down harness. Also did the crank flutter bypass. Still no good. The engine was a perfect running engine b4. I have to assume it's wiring or computer related. Any help appreciated. I don't know much about Hondas. This is a steep learning curve for me.
Old Jul 13, 2015 | 04:30 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Help!!! D series to b series. Won't run
Did he convert to manual? If not what transmission did you use? You didn't list your model but did you conver the idle air control valve to 2 wire? Pull and post the check engine codes.
Old Jul 13, 2015 | 05:12 PM
Lou1267's Avatar
He did convert to manual
I didn't do the 2 wire conversion yet
Can't get the code scanner to work
Old Jul 13, 2015 | 05:17 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
the code scanner wont work because he used a obd1 ecu. there isnt a 2000 b16 acura motor. you mean a b18b from the integra? he can get a obd2a ls ecu(not sure if it has an immobilizer)your son has to do the 3>2 wire for the iacv. he has to get the obd2b to odb2a harness, if they even make one. did he switch the tps sensor and the map sensor?
Old Jul 13, 2015 | 05:43 PM
Lou1267's Avatar
Tps and map are on the new 18b motor I think
I
Old Jul 14, 2015 | 05:03 AM
Ferio Wdm Edition
But are the connectors switched?
Old Jul 14, 2015 | 12:25 PM
Lou1267's Avatar
Are they interchangeable?
Old Jul 14, 2015 | 01:13 PM
Lou1267's Avatar
I have a video of how it's running. But can't post it
Old Jul 14, 2015 | 01:32 PM
Lou1267's Avatar
They were reversed. Car runs. Thank u so much
Old Jul 14, 2015 | 04:24 PM
Lou1267's Avatar
Where would I find the coolant sensor on a b16 engine
Old Jul 14, 2015 | 04:38 PM
Technical Hero
Round two prong sensor on side of the head. The round one on the thermostat hosing is the fan switch.
Austin Dube
Mar 6, 2018 12:01 PM
sh!ft
Transmission & Drivetrain
May 5, 2014 05:14 AM
spidermancivic
Jul 21, 2009 09:58 PM
Phaze2 Mike
May 30, 2005 06:40 PM
rcav
Aug 24, 2004 05:23 AM
