Turn signals dont work
Old Jul 13, 2015 | 10:04 AM
Marks accord's Avatar
Default Turn signals dont work
Have a 98 accord. Turn signals were working fine when i got the car until i used the hazards. Then it blew the fuse on the driver side panel and then the hazard fuse under the hood. Both were replaced but now the turn signals dont work. Tore apart the colum and found the wires which are (green w blue line.green w red line.green w yellow) i have power coming in but im not sure if its the right wire for the signals. Does anybody have a pigtail diagram or wiring diagram for this?
Old Jul 14, 2015 | 04:21 AM
Lost Again's Avatar
Default Re: Turn signals dont work
If all of this started when you used the hazard switch, I'd start testing there first
Anyway here is the comb switch test
Old Jul 14, 2015 | 05:19 AM
Thanks for the diagram. I did go back to the hazard switch and after 3 hours of fustration and dismantling the dash i changed out the hazard switch and it worked out fine. So signals and hazards are working fine now. There may be a something in the hazard switch that opens and closes the circuit to the turn switch. Idk but its working!!!
Old Jul 14, 2015 | 09:03 AM
Lost Again's Avatar
Yes, the hazard switch is the "first part" in the circut. So if it is bad or unplugged the turn signals will not work.
Glad you got it going
Old Jul 14, 2015 | 06:30 PM
Ya me too
GabeBellaflores
Jan 16, 2019 02:15 PM
amb4081
Nov 21, 2012 07:29 AM
evrythng_fast
Jul 9, 2011 03:46 PM
chrisff521
Mar 6, 2010 08:02 PM
wseg
Mar 3, 2010 03:35 PM
