Transmission & Drivetrain Gearboxes, Differentials, Clutches
No tension in clutch cable
Old Jul 13, 2015 | 09:15 AM
HypL's Avatar
Default No tension in clutch cable
hey guys-
Car is a 1993 Integra rs (not hydraulic clutch) installed a jdm type r motor and a ys1 cable tranny I had built by syncrotech... The trans is great and ran it with my old motor for about 2,000 miles.... I just installed a new act prolite flywheel, oem pilot bearing and reused the jdm ITR clutch that looked in good shape.... I just hooked up the clutch cable and notice the lever on the trans has NO tension on it.... With the cable attached the clutch pedal just falls to the floor... It feels exactly like there is no throw out bearing installed inside the trans. The throw out bearing is oem and also had only 2,000 miles or so.
Is it possible the clutch release bearing came off of the lever inside the trans or something? This IS NOT a clutch cable issue ... I can lift the lever on the trans with no effort. I'm sure I'm going to have to drop the trans again which I don't want but what could be the problem... At first it seemed the lever had tension then all of a sudden lost it.
P.S I only have 1 axle installed and no shift linkage as of right now.
Thanks peeps!!!
Old Jul 14, 2015 | 06:57 AM
HypL's Avatar
Default Re: No tension in clutch cable
Could it be that the throw out bearing separated from the fork that it pivots on inside the transmission?
Old Jul 14, 2015 | 08:10 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You could remove the starter and use a mirror and flashlight to see if you can see anything. It's not ideal, but I have done it on more than one occasion. It is always a possibility the TOB came loose if the spring was installed wrong / backwards. I have seen it done before... basically if you can't see what's going on you are going to have to drop the transmission anyways. Shouldn't take very long.
HypL
Jul 13, 2015 09:44 AM
raymondpowens
Apr 25, 2015 12:02 AM
kid_02131
12
Nov 6, 2013 05:32 AM
90civic1.5
Feb 17, 2010 09:29 PM
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
