2000 Honda Accord Suspension/Body/Chassis Issue?
Old Jul 13, 2015 | 08:12 AM
hondaaccord295's Avatar
Icon2 2000 Honda Accord Suspension/Body/Chassis Issue?
I have a 2000 Honda Accord, 4 door EX V6 with 250,000 miles.
I have noticed a rotted area about the size of a peach pit roughly located beneath the heater core (Could dripping from A/C condensate have caused the problem?).
Bottom of the frame is solid with no rust. No symptons, car stands perfect, etc.
Could this rot lead to a "collapse" of the car? It was not garaged, living in NJ where there is road salt in the winters.
Or is this a common area of rust in Honda Accords not to be worried about?
Attached are some photos.
Old Jul 14, 2015 | 03:00 AM
Lost Again's Avatar
Default Re: 2000 Honda Accord Suspension/Body/Chassis Issue?
It is a common area to rust on that gen Accord.
It is something to worry about, no the car isn't going to "fall apart" but if and when the subframe does rust through, there will be all kinds of noises and strange feeling in the suspension.
Suggest you start searching bone yards for a replacement, you can use places like "car-part" dot com to help locate one. Changing it is not that fun but isn't that hard.
Old Jul 14, 2015 | 10:29 AM
Thank you for the response!
Old Sep 28, 2023 | 02:50 PM
Ancient one's Avatar
I have the same problem with a 2000 accord; could you please tell me what that part would be called? Thanks.
Memyself3
Nov 10, 2017 07:51 AM
kofimark
Nov 18, 2004 05:25 PM
