99-00 civic si ET's and mods
I'm trying to get an idea of what times I should be running, or will run. Please list mods and times. I'll go first
60ft....2.487
1/4.....15.723 @ 89.9 mph
2000 civic si with short ram intake
[Modified by BoTtLeFeDCRX, 5:10 AM 11/5/2002]
60ft....2.487
See sig for ET/trap...I hit a 15.5 on the brakes in Pomona, and one run was even at 90mph!!!
I do have an unhelpful K&N drop-in filter, other than that, the car is run with everything else stock and full interior. My 60ft times range from 2.3s to 2.4s.
spoonfedeg.............tires are extremy bad....like 30% tread left. I just wanted to see what my car could do as it sat......like on the street, so i didn't even dro tire pressure, still runnin' on 36 psi. Ill have lots more mods when i bring the car back ut in the spring and hopefully mid 14's.
13.41@105.73.. 2.1 60ft. 8 psi......................This was done on the stock B16 block with a JG Proseries head running B16 cams. Since then car has fully built LS-VTEC motor, but no times yet car is still being tuned.
el arbi
Sep 10, 2003 11:55 AM
