Weird Idle after cleaning IACV (Video attached)
After cleaning the iacv I get this weird idle:
Replaced the gasket and bleed the coolant, but nothing happens.
After idling for about three minutes, it drops to the correct RPM and everything is normal.
This happens on cold start.
Do I have to adjust the idle screw or something after cleaning iacv? Any ideas fellas?
Easy way to find a vacuum leak is go buy a cheap Halloween fog machine, open up a vacuum line and blow the smoke in. Watch where it comes out, their "professional" smoke machines are a complete ripoff, honestly you could use a cigar and blow the smoke through for $1 (Thank scotty kilmer for that one).
BlackJacket
Dec 16, 2013 02:52 PM
joelmatt89
13
Mar 9, 2009 07:03 AM
